Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Bad valve adjustment
Old 02-14-2013, 06:54 AM
vinniekq2's Avatar
vinniekq2 vinniekq2 is offline
very nice looking car
make sure you retorque the wheels to make sure the new studs take a set.
re:#2, the wire is not touching the header,the plug is not fouled,and maybe take that cover off again,,,check valve movement and check spring for bind and or broken damper
