Bad Valve?? or bad carb? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-12-2013, 11:08 AM
My 1985 350 sbc has ping/knock. The engine was rebuilt about 5 years ago. It has a mild cam and edelbrock intake. It started knocking about month ago. Been parked since.
When i give it gas under load she knocks and has little power. It sounds like its on the driver side. Its not a loud knock its just kinda there. But ive tried everything, adjusting the valves. advancing and retarding the timing. New plugs and wires. But the fuel filter was clogged bad. So i changed that out and still the same. She sounds like its missing the way the exhaust sounds on the driver side.(dual exhaust) but the passenger side sounds normal. I need input here.. Bad exhaust valve??Bad carb?? Spark Knock?
Old 02-12-2013, 11:35 AM
vinniekq2's Avatar
compression test/leak down test
The Following User Says Thank You to vinniekq2 For This Useful Post:
OldSchool350 (02-12-2013)
Old 02-12-2013, 03:10 PM
RWENUTS's Avatar
Flat cam!!
Old 02-12-2013, 03:49 PM
T-bucket23's Avatar
Wiki Edits: 26
Carbon buildup, broken valve spring, flat cam. I would start it with the valve cover off and see if everything is moving to start with.
Chet
Old 02-12-2013, 07:32 PM
All the valve springs move and the valves are set at 0-lash. Seems to me like one of the cylinders are not combusting right. i think ill go with vinnies opinion. Just need me compression tester now
Bad Valve?...How do you tell? High School Hot Rod Engine 11 06-21-2010 10:25 PM
Bad Valve?...How do you tell? High School Hot Rod Engine 2 06-19-2010 12:04 AM
Bad Cam, Bad, Bad, 327 MosinNagant Engine 6 12-30-2009 08:56 PM
Bad valve mudkat Engine 3 04-05-2007 06:35 PM
Tightened My Valve Train.........(One Bad Valve?) white66coupe Engine 1 08-23-2004 10:00 PM
