Bad Vibration help! - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-14-2006, 11:47 PM
Bad Vibration help!
I am driving a 79 mustang now. recently i got rid of the 4 speed and put a t-5 in it out of a 87 stang. The problem is that in 4th gear at high rpm i would say around 5000 and in 5th gear i get a vibration thats starts at about 2000, and then will end at about 3000 rpm. I have 4.10 gears. It does it when I am in netural or have the clutch it when I am at around the same speed. . I have never changed the tranny mount or u joints, it just kinda flared up after the new tranny. What do you guys think this could be?
thanks
Trent
Old 09-15-2006, 12:12 PM
You didn't use a poly trans mount did you? Tough to tell if it is a driveshaft vibe or out of balance tires.
Old 09-15-2006, 12:54 PM
strummin67's Avatar
Violating consensual reality
Last journal entry: It tows!
Did you change the yoke on your driveshaft?
Strummin
Old 09-21-2006, 11:30 PM
The only thing that i changed was the transmission,and i used the tranny mount that was on the transmission already, everything else is exactly the same.
Bad brake booster? NOlowrider Suspension - Brakes - Steering 4 05-26-2005 12:39 PM
vibration problem? voodoosurfer Transmission - Rearend 4 05-11-2005 08:08 PM
Vibration at speed Doc68 Transmission - Rearend 141 01-22-2005 07:53 PM
engine vibration / harmonic balancer briansansone Engine 4 11-01-2004 09:29 PM
how bad is it to ride on bad akm Suspension - Brakes - Steering 5 05-13-2003 09:28 PM
