Bad Vibrations - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-21-2007, 06:29 AM
Malibucdl's Avatar
Laissez les bons temps rouler
Last journal entry: Frame Removal
Originally Posted by RPM
I used to work for Goodyear as a service manager. Check these tires for out of round. Run a pc of masking tape around the tire and check the run out with a dial indicator. No more than .100" run out allowed. Check the wheel run out no more than .050" lateral or radial allowed. Do all this on the car and recheck on the wheel balancer. Sometimes the tire can be moved on the wheel to help get rid of run out. You can balance a square block but it won't ride smooth.
I can probablly borrow a dial indicator from work, especially since I am QA Tech and have several at my disposal.
I just realized that I never mentioned what type of tires I had. They are GoodYear Eagle GT HRs.
  #17 (permalink)
Old 09-21-2007, 06:41 AM
wildman1932's Avatar
Dave's hot Rod Shop
One of the fastest ways to eliminate the tire from the equation, is to borrow or try a different set of tires. If it goes away, it in the tires. Then start looking at the drive shaft ect.
Also, if you can still find an (on car balancer) it will check the rotors at the same time.
  #18 (permalink)
Old 09-21-2007, 03:26 PM
I used to
Use that on the car balancer.You can't find them any more.They were the best
  #19 (permalink)
Old 10-02-2007, 01:55 PM
Malibucdl's Avatar
I believe I found the cuprits. I was rotating the tires this weekend and when I grabbed the front tires i was jabbed in the hand by the steel belts sticking out of the inside shoulders on both tires. I am 99% sure that the excessive wear on the inside shoulders of the tires was caused by the -1.5* camber that I am running on the rear of the car. This negative camber is from the lowering springs that are installed on the car, and the fact that I never did install a camber kit on the rear because I wanted the impovement in handling. Now, I will admit that I do like the handling that the negative camber has given me, but I'm not to sure if it is worth it if it is going to be eating up tires like this. I might just have to get the camber kit and fix this so I'm not replacing tires every year. As for now, I'm going tomorrow morning to get 2 new Goodyear Eagle GT HRs at the cost of ~250 installed.
Chris
  #20 (permalink)
Old 10-02-2007, 06:36 PM
you really don't need that
Much camber on a street car.besides that car runs on rails in stock form.
bad running engine roycecas1 Engine 7 08-18-2006 06:37 AM
2 out of 5 ain't bad....right? WakBordr7387 Hotrodders' Lounge 13 01-29-2006 10:27 AM
I need my bad luck to go away..... onebadmerc Hotrodders' Lounge 5 01-23-2004 09:08 PM
is this repetitive bad luck or what? 71gtx Engine 4 11-18-2003 08:19 PM
how bad is it to ride on bad akm Suspension - Brakes - Steering 5 05-13-2003 09:28 PM
