Baffeled headers ??
I am runnig straight headers on my 1935 Ford Rat rod (460 big block ) , has anyone ever ran motorcycle baffels inside the tips of the header pipes and do they work very good ?
not sure about motorcycle baffles but they make auger style inserts for headers that supposedly improve power over open headers while reducing decibals not sure about the power improvement part but a circle track buddy of mine swears by em since the implementation of muffler rules at the local tracks
| The Following User Says Thank You to superdime For This Useful Post: | ||
steveb1124 (10-27-2012) | ||
thanks for your reply, have you herd of any name brands or who may carried them ?
| The Following User Says Thank You to 327NUT For This Useful Post: | ||
steveb1124 (10-28-2012) | ||
i found some inserts , by a company called Patriot that i think will work. Thanks for yalls reply
actually i think patriots are the ones i was talking about i see them in speed catalogs all the time
yea but the smallest that i have seen is 3" ID and my pipes are 1 1/2"
Id . I am going to try and call Patriot tomorrow and see if they will build them for me as i will need 8 of them . |
ok so i was thinking you had collectors the ones i was refering to are collector inserts sorry about that if patriot can't do it i honestly don't see a reason why motorcycle baffles won't work as 327 nut mentioned ebay would be your best source for a good price but they may cut power a little don't quote me on that but from what i know about motorcycles most are tuned for a specific amount of backpressure so the baffles are probably gonna be a bit restrictive good luck though and let me know how things turn out because i would like to do something similar as what your trying when i get to my own rat project i've always loved the look of zoomies but don't like tickets...sound police are pretty strict in my area happy rodding!!!!!!!!!!!!
yea , i want to do some more research on the motorcycle baffels , if Patriot cant help me out. Thanks for your input.
A friend of mine had zoomies on his street rod; they were sort of a 'street zoomie' I guess you could say. They had what was essentially a cup with a hole drilled in the bottom; inserted in each pipe. Think like a spraypaint can top with a hole drilled in it.
T bucket guys have used motorcycle baffles in custom headers for years. They will burn out and need to be replaced so make sure you can remove and replace without much hassle. |
| The Following User Says Thank You to AutoGear For This Useful Post: | ||
steveb1124 (10-29-2012) | ||
Not sure if they still make them, but they used to have a baffle for straight pipes that looked like a washer with a knob on one side. Took a single 3/16" or 1/4" hole in the side of each pipe to install them. A 1/4 turn on each knob would close them to restrict sound, or open them to make them straight pipes.
We used to make them up ourselves also to save money. Weld a 1/4" all thread rod to the side of a 1.5" washer, then drill the exhaust and feed the threaded rod through the pipe. Put a small spring on the outside, then a nut, and lock it against a wingnut. You have a cheap, easy baffle, that can be turned to either direction to quiet it down, or leave it noisy. |
| The Following User Says Thank You to BigEd36 For This Useful Post: | ||
steveb1124 (10-30-2012) | ||
Post back after you get this resolved and let us know the results. I'd be more interested in the power loss than the noise issue...
Russ |
10-4 will do
| Will any other headers work on chevy s10 v8 besides swap headers? | eric32 | Engine | 3 | 01-29-2010 05:39 PM |
| headers??? whats so good about headers, compaired to stock exhaust manifolds? | bigno09 | Hotrodding Basics | 7 | 11-12-2009 03:34 PM |
| Block hugger headers vs Long tube headers | sexypizzaman | Engine | 12 | 05-01-2008 01:54 PM |
| Block Hugger Headers vs Regular Headers | 63ChevyII | General Rodding Tech | 7 | 05-07-2005 10:15 PM |
| tri y headers or standard full tube headers | fordracing | Engine | 10 | 06-13-2003 06:39 AM |
