Bag Placement - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-25-2007, 03:25 PM
GMracer's Avatar
Bag Placement
Im building a prostreet style silverado... but I am also running air ride on it for the looks/comfort. Now since my rear wheels will be 12" wide I need to run a inboard 4link. Which is fine, but now my bags are most likely going to have to be mounted on the front of the axle, so I can run a panhard behind, otherwise the bags would interfer. My question is say between the rails is roughly 48", the 4link takes up 5" on each side would the bags be too close together in the middle to ride right and be able to transfer the weight correctly. Its a powerful motor, 700hp... so I need this to hook and ride perfectly. I just dont know if the bags are going to be too close together and cause alot of unwanted side to side movement.
Thanks for the help in advance, its good to finally found someplace that knows there stuff when it comes to suspension setups.
1990 lincoln mark 7 leaky right front air bag suspension fasteddiesage Suspension - Brakes - Steering 3 10-06-2006 09:49 PM
Air Bag Mounts H2Os50 Suspension - Brakes - Steering 2 03-14-2005 05:56 AM
Need help installing the right size Air bag on 1952 chevy coupe stock suspension. Kuztmchev52 Introduce Yourself 1 07-14-2004 11:00 PM
Will a bag this size work? HemmiGremmie Hotrodders' Lounge 2 04-15-2004 04:58 AM
Air Bag Eliminators adtkart General Rodding Tech 6 01-18-2004 05:22 PM
