Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Balance confusion on 383...
Old 08-03-2012, 06:35 AM
CNC BLOCKS NE CNC BLOCKS NE is offline
Originally Posted by vinniekq2 View Post
how did they balance the engine with out all the rotating parts? including balancer and flywheel/flexplate,,,clutch or convertor should be sent in also.Dont forget to balance your new driveshaft too
You don't balance clutches!! You migh blanve the flex plates and clutch covers!!!
If you use a neutral balancer they are fine from what I have seen.
A convertor is filled with liquid no need to balance.
