balancer - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-23-2007, 08:08 PM
balancer
Hi, I am having problems keeping the balancer on my sbc 400 it has eagle crank, 5.7 rods, sfi fluid damper, manual trans, and 6300 rev limiter.
I ran a stock balancer for a long time until it broke (crack the hub) replaced it w/sfi balancer and can't keep it on it shears crank keys and loosens the bolt. anyone else have this problem?/?
Old 09-23-2007, 08:19 PM
Notorious's Avatar
Hot rodder, not street rodder!
What's the part# of your crank? And since you're now using an aftermarket damper, you may as well give me it's number too.
Old 09-23-2007, 08:36 PM
I'll check on monday
Old 10-02-2007, 06:39 PM
hey I found a machine shop that could cut an extra key in the crank and in the balancer hope this works thanks jamie
Old 10-02-2007, 06:42 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Check the interference fit between the balancer and the crank. I took an Eagle crank to a machine shop and they informed me that the snouts on their cranks often come undersized. Sure enough, mine was undersized .0015. I had to make sure my intended balancer i.d. small enough that it would still work.
Old 10-02-2007, 07:50 PM
it is an eagle crank, I will have the machine shop check it thanks jamie
283 Harmonic Balancer JamesD Engine 29 03-14-2007 05:36 PM
Can I grind on the balancer? fastrehotrods Engine 4 05-19-2006 07:47 AM
Harmonic Balancer Installation DTL504 Engine 2 06-15-2004 10:17 AM
balancer bolt broke while driving, im 500 mi from home. Jared Engine 10 10-27-2003 11:13 AM
sbc 327 vs 350 Harmonic Balancer Question Ted's37 Engine 3 07-14-2003 04:10 PM
