Balancer bolt from bolt supply store?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-19-2008, 06:58 AM
v8hed's Avatar
AK427
As I've mentioned in another thread, I need a longer-than-stock balancer bolt for my 350 SBC due to damaged threads at the front of the crank snout. I was all set to order an expensive ARP balancer bolt, which is 2.47" long (compared to the 2.25" stock bolt), but then decided to see if I could get a 'generic' bolt of the correct specs from a specialist bolt supply store. Amazingly, I can get a suitable bolt from them for only $3.50 + shipping! This price seems so low, I want to make sure of the specs. Can you guys confirm this is suitable?
7/16" UNF
20 TPI
5/16" stud head
Zinc plated
High Tensile metric Grade 10.9 (equiv to Grade 8)
Thanks.
Old 08-19-2008, 07:37 AM
Frisco's Avatar
Glad To Be Here
7/16" UNF
20 TPI
5/16" stud head
Zinc plated
Thanks.
Buy it if you are satisfied with the price! It will be fine and plenty strong enough.
If that is $3.50 in US dollars it seems to be high priced, even for a grade 8 zinc plated hex head bolt. I guess it may be a "special" order for you in the UK though since you use the metric system.
Old 08-19-2008, 08:11 AM
540z's Avatar
Brute force and ignorance.....
What is a "stud head" bolt?
Just for clarification, what is a 5/16 "stud head" bolt on a 7/16-20 UNF thread? On your side of the pond is that the same as a socket head in the US? BTW, have you got your balancer all the way on yet?
Just curious,
TR
Old 08-19-2008, 08:17 AM
v8hed's Avatar
AK427
Just curious,
TR
Excuse my gaffed attempt at trying to translate into American English... it's what we call a 'socket cap' bolt.
Yes, the balancer is all the way on. I mocked-up the crank pulley and mocked-up the alt. belt between the water pump pulley and the crank pulley and it ran in a straight line between the two.
Old 08-19-2008, 08:43 AM
540z's Avatar
How long is this new bolt? How deep are the threads on the crank snout?
Personally, I'd use a hex head bolt as opposed to a socket cap. I'd prefer to use a 5/8" socket wrench over a 5/16" hex key any day, especially if you are rotating the engine with it. I've rounded off too many socket heads in my day.
Just my 2 cents.
TR
Old 08-19-2008, 06:37 PM
v8hed's Avatar
AK427
Just my 2 cents.
TR
Hmm, yea, I might just get the ARP bolt... it's sooo expensive though (around $30 over here). Length is 2.47" under the bolt head, compared to 2.25" stock. The face of my new balancer protrudes (without actually measuring it) ~0.75-1.00" beyond the crank snout. I'm ASSUMING that a 2.47" bolt will be OK without bottoming-out. By the way, what is actually at the 'bottom' of the crank snout? Just a solid iron wall?
Old 08-20-2008, 05:30 AM
540z's Avatar
Send me a PM. Let's get this worked out.
TR
Old 08-20-2008, 06:24 AM
31 five window
Last journal entry: grill and rear end
What he said is correct. I would use a hex head cap screw or bolt over a socket head cap screw or bolt also. They should be available from the same place you can get the socket one. Just use grade 8 and you will be fine.If you can't find one PM me and I will send you one.
Old 08-20-2008, 06:26 AM
31 five window
Yes ,just solid iron.
SBC harmonic balancer install v8hed Engine 14 08-17-2008 04:10 PM
locking up the motor to tighten the harmonic balancer bolt? darkostoj Engine 6 05-16-2008 06:48 AM
Harmonic Balancer help sexypizzaman Engine 4 02-11-2008 04:21 PM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 06:50 PM
2 bolt to 4 bolt swap and 2 bolt strength???? HemmiGremmie Engine 8 10-20-2002 03:06 PM
