Balancer at fault? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-14-2011, 09:32 AM
Balancer at fault?
I bought a stock 1989 350 with a 700r and installed it in my rod. I started it up, ran it (and it ran fine) and then decided to tune it. Took out my timing light and proceeded to set the timing. To my surprise there were no marks to line up with the pointer. I then dialed the timing light and the mark finally came into view until it lined up with the pointer. The timing light was now set a 40 degrees! Could it be that I have the wrong damper or has the rubber/silicone let go between the two parts of the damper causing it to spin? I know that GM used different dampers, but would the wrong one throw out the marks that much? Any help would be greatly appreciated.
Old 09-14-2011, 09:37 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Anyone who begins a project with a motor that already runs or has been rebuilt (yeah, right!) needs to go through this routine before they do anything else to the motor....
http://www.crankshaftcoalition.com/w...op_dead_center
I jumped into a question My fault CodyC10Kid Introduce Yourself 3 12-27-2009 07:19 AM
Paint bubbles! Who's at fault? DaSouthWon Body - Exterior 6 05-23-2009 06:53 AM
97 Civic Alternator Q- it's my gf's so it's not my fault ChevelleSS_LS6 General Rodding Tech 18 10-15-2007 10:13 AM
So, who is at fault? MARTINSR Hotrodders' Lounge 32 01-12-2006 05:19 PM
OK, Willy's this is your fault!! Bluepen Body - Exterior 5 08-18-2004 04:56 PM
