balancer-pulley question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2008, 03:13 PM
I have a 259 dodge V8 engine from 1955. Originally this engine does not have a balancer on the crank. Because the main reason these engines break down is due to a crack in the crank I sure want to have a balancer on it.
I bought a standard balancer, new modified 340-type damper with timing marks indexed every 90� for Hot Heads and OE pre-'57 timing covers . For street performance use from Hotheads. With this a V-belt pulley. Now I'm to the point of putting it together I discovered the pulley in 1 inch short in hight. So the crank V-belt pulley does not align with the waterpump pulley.
According to Hotheads the only solution in to mount a '57/'58 mopar crank pulley on this damper. This should bring the crank pulley in alignment with the waterpump pulley.
Dimensions of the balancer:
-) 6 bolts, equally placed at 60 degrees at a pitch circle of 71.2mm = 2 4/5 in.
-) bolt diameter: 6 bolts of 7.84 mm = 0.3 inch
-) flange on the balancer where the pulley goes over: 57.15mm = 2 1/4 inch
-) Pulley hight from balancer to the front edge of the belt (including the thickness of the belt: 47mm =1.85 inch
-)Total hight of the pulley = 56mm including the flange for the timing marking.
-) Pulley diameter now used: 7 1/2 inch. I think this is very big. Do not know if it is ever used again. So if a smaller pulley diameter is available it should do with an other V-belt.
Question: Does anyone know what car(s) had a pulley that could fit my engine.
I did try to attach two pictures, one of the balancer, one of the hight difference between the old and new situation.
Thanks, Edwin.
ID:	28371   Click image for larger version
ID:	28372   Click image for larger version
ID:	28373   Click image for larger version
90s SBC Power Steering Pump pulley Removal Help Mustangsaly Engine 12 10-08-2006 06:00 PM
Squeeling Fan Belt - Out of true Pulley Billy Boy Engine 3 02-15-2005 06:51 PM
283/327 harmonic balancer /damper Question 59vette Engine 5 11-16-2003 11:42 PM
Crank Pulley / Harmonic Balancer surfrat6 Engine 2 09-01-2003 05:33 PM
Harmonic Balancer markiemyster Engine 3 05-09-2003 06:31 AM
