ball joint castle nut too short - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-09-2007, 12:56 AM
Hi Guys,
After three building years I am finally bolting everything together on my project. It is a mustang II type front end and I will be damned if the castle nuts on the lower ball joints are too short to properly install the cotter keys. The drilled hole for the cotter key is way too high on the ball joint stud to secure the castle. There is approimately 1/2 inch space between the drilled hole and the castle nut top.
What to do? Do they make taller castle nuts? Is it ok to use some sort of spacer? I can`t imagine trying to drill a new hole in the right location on the ball joint stud. Any help appreciated. thanx, Bob Myers, SD.
Old 01-09-2007, 01:27 AM
staleg's Avatar
Last journal entry: Hand brake
On my Fat Man M II kit a spacer was enclosed because of this.
Spindle interchanges bskaggs Suspension - Brakes - Steering 11 06-05-2006 02:29 PM
Camaro ball joint questions ModelAMan Suspension - Brakes - Steering 1 06-13-2005 03:03 PM
Front Ball joint ... PICTURE bg Suspension - Brakes - Steering 17 04-16-2005 02:24 AM
ball joint question RustBucketChevy Suspension - Brakes - Steering 4 11-06-2003 10:13 PM
79 Suburban Ball Joint change Help!!! mr_chickenhead Suspension - Brakes - Steering 2 01-09-2003 09:08 PM
