ball joint fit - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-09-2008, 05:00 PM
ball joint fit
I need to know what is the tollreance or clearance for a balljoint example I have a hole in a tubular a arm for the ball joint to press into how many thousands do I want for a press fit between the joint and the hole ball joint has knurles thanks
Old 12-09-2008, 08:12 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Damn tight! prolly like -.010
You can weld em up too.
Old 12-09-2008, 08:48 PM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
Don't be afraid to put a little heat on the a-arm before pressing the ball joint in. Even warming the a-arm in the oven a while will help if you don't want to damage paint with a torch. Chilling the joint helps too...
Old 12-09-2008, 08:52 PM
ball joint
thanks guys the reason I ask was right now the hole and the ball joint are 30 thousands differrence no one would press it said to big of a difference my buddy is a machinist and thought 10 thousand was right but wanted it verified before he opened up the hole for me and pressed them in
Old 12-10-2008, 05:50 PM
balljoint
got them machined and pressed in today went 10 thousand he said it was a real tihgt fit could have gone 5 -8 and been alright just gladto have it done
Ball Joint Question ceh383 Suspension - Brakes - Steering 6 07-12-2008 12:46 AM
Ball joint install 39chevy Suspension - Brakes - Steering 3 03-11-2007 08:14 AM
Need some help,want to convert to disk EazyDuzIt102 Suspension - Brakes - Steering 23 02-16-2007 07:16 PM
'99 ford van ball joint replacement mad55chevy Engine 3 04-23-2005 07:37 AM
49-51 Ford Ball Joint Suspension & Disc Brakes 51shoeboxford Suspension - Brakes - Steering 2 01-28-2005 10:04 AM
