Ball joint install - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2007, 11:44 AM
Ball joint install
I have 51 Stude Trk and I am staying w/original steering! My question is the steering bar runs from my steering box to right wheel. All I have to do is put each side of the joint up and through the hole. It is a pretty tight fit, how do I get that in there without hammering it to death and screw something up? How far also should it seat, because it seems that my nut to tighten down doesn't go on very far to accept the cotter! Advise, thanks, Dana
Old 03-10-2007, 07:12 PM
BOBCRMAN@aol.com's Avatar
The holes should be tapered. The tie rod ends are also tapered. When correctly installed, the threaded portion of the stud will protrude far enough to install a nut or nut and hard washer.
If the tie rod stud does not stick thru far enuff. the stud is too big. Try a different tie rod end.
Old 03-10-2007, 08:04 PM
does the problem exist on both ends of that rod? I have the front end from a 49 Stude and there is a small spacer at the spindle end. this spacer looks to be about 1/8 inch and fits between the tie rod end and the spindle, basically at the top of the boot. it seems to me that this would make your problem worse. Chances are you have the wrong tie rod ends.
Old 03-11-2007, 08:14 AM
Thanks for the info, My threaded stud does go far enough thru so to accept a cotter, my steering box side has a little longer space then spindle side but doesn't affect anything! I will just put an extra spacer in there, thanks again, Dana! TERRIFIC SITE as always!!!!!
Spindle interchanges bskaggs Suspension - Brakes - Steering 11 06-05-2006 01:29 PM
Camaro ball joint questions ModelAMan Suspension - Brakes - Steering 1 06-13-2005 02:03 PM
Front Ball joint ... PICTURE bg Suspension - Brakes - Steering 17 04-16-2005 01:24 AM
ball joint question RustBucketChevy Suspension - Brakes - Steering 4 11-06-2003 09:13 PM
79 Suburban Ball Joint change Help!!! mr_chickenhead Suspension - Brakes - Steering 2 01-09-2003 08:08 PM
