Ball Joint Rplacement
Hi there, Can anyone recommend any literature or does anyone have any advice on replacing ball joints on a 95 ford f-150 4x4. I've never done these and I need to do them myself since I got a quote from a mechanic around $800 for all 4 ball joints, both u-joints, and both hub locks. I don't have 800 bucks so if anyone can help I sure would be grateful. I did rent a press tool but I'm not sure if there are any other tools,other than the ordinary, that I should rent. HELP!! PLEASE!! JSP
Go to www.autozone.com and look up the repair info. They don't have all the older stuff but something newer like your ford should be up there. If you have the money just buy a manual...it will save you a lot of hassle in the long run.
You will need a spindle nut socket (round tube with 4 prongs). I don't think you need anything special to adjust the ball joint preload (you do on the older solid axle stuff). Don't use cheap ball joints. Perfect Circle and Moog are good stuff. If you are going to do the u-joints the ONLY part you want to use is Spicer 5-760x (assuming you actually use the 4wd...if you only use it in the snow a few times a year buy whatever you want). If you are going to do the rest you might as well replace the outer axle seals and bearings (part # BK1), the wheel seals, and repack the bearings. FWIW I think $800 is a good price for all that work. Searching on google for TTB (Twin Traction Beam or Twin Torque Beam I don't remember) with something like ball-joint how-to you will also come up with some good info like this http://therangerstation.com/tech_lib...allJoints.html |
Thanks guys for all your advice. I think I'm on the right track. Now I just have to get it done! JSP
Be very careful when you take the hubs apart to be sure everything goes back together the same way. Some guys like to use their digital camera to take pictures as they go along. Don't forget a good torque wrench for reassembly.
| Spindle interchanges | bskaggs | Suspension - Brakes - Steering | 11 | 06-05-2006 01:29 PM |
| Camaro ball joint questions | ModelAMan | Suspension - Brakes - Steering | 1 | 06-13-2005 02:03 PM |
| Front Ball joint ... PICTURE | bg | Suspension - Brakes - Steering | 17 | 04-16-2005 01:24 AM |
| ball joint question | RustBucketChevy | Suspension - Brakes - Steering | 4 | 11-06-2003 09:13 PM |
| 79 Suburban Ball Joint change Help!!! | mr_chickenhead | Suspension - Brakes - Steering | 2 | 01-09-2003 08:08 PM |
