Ball joint size - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-07-2013, 10:11 AM
Mutt's37Buick's Avatar
Ball joint size
Can someone tell me what the ball joint size (1/2, 9/16, 5/8, etc...) designates?
I'm assuming it's a diameter, but not sure what it references.
Thanks
Old 05-07-2013, 11:40 AM
astroracer's Avatar
That's the size of the nut that holds the joint together.
Old 05-07-2013, 11:43 AM
Thanks for this information. Thought that was a possibility but could not find verification.
Old 05-07-2013, 10:28 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The ball joint is sealed. The hex size of the nut on the stud is bigger than what you're describing. It sounds possibly like the diameter of the threads on the stud.
Old 05-08-2013, 03:09 AM
astroracer's Avatar
Yea, Nuts are called out by the thread size, not the flat width.
s10 ball joint/ 4runner ball joint stevetankl Suspension - Brakes - Steering 1 06-16-2012 01:59 AM
ball joint reamer ?? awert Suspension - Brakes - Steering 1 04-04-2012 10:30 PM
68 gto ball upper ball joint removal question adam83 Suspension - Brakes - Steering 25 01-04-2011 01:39 AM
Ball Joint Question ceh383 Suspension - Brakes - Steering 6 07-12-2008 12:46 AM
Ball joint install 39chevy Suspension - Brakes - Steering 3 03-11-2007 08:14 AM
