Ball Joint spacers - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-30-2005, 06:36 PM
bct bct is offline
Ball Joint spacers
Does anyone still make the "C" type ball joint spacers for the front of a 55 chevy? I've seen another style that goes on above the upper ball joint, but am unsure if they will cause the car to have a higher stance when parked. Thanks for any info.
Old 11-30-2005, 07:14 PM
39 chev's Avatar
Last journal entry: new pictures of T-bucket
ball joint spacers
Neither one of these spacers will change the heigth of the vehicle,they will give you more travel,so you can use heavier springs or spring spacers to get the heigth you want. I did put ball joint spacers in a 64 nova,raised it about three inches, because the coil spring is on top of the upper control arm. The nova had a nice"gasser" stance but it was a ***** to keep the front end aligned.
Old 11-30-2005, 08:11 PM
bct bct is offline
I've seen 1 inch rubber coil spring spacers. Can you get thicker ones to give more lift?
Old 11-30-2005, 08:43 PM
techinspector1's Avatar
Wiki Edits: 326
The spacers that mount on the top of the spindle introduce more angle into the upper control arm to increase negative camber gain in turns to prevent the tire from rolling over and to keep the tread flatter on the road surface.
If you're trying to get a little more height in the front end, call these spring experts and order a set of longer springs. You might want to install shocks with a longer travel also, so you don't run out of shock rod travel.
http://www.eatonsprings.com/
Old 12-01-2005, 03:46 PM
Like this?
Dukes pics
Old 12-03-2005, 07:39 AM
bct bct is offline
Yes Duke, those are exactly what I was thinking of. The first time I saw them was in an article in Hot Rod Magazine. I believe the owner of the car was Rick Delgado (not sure of the spelling) His 55 sat pretty high. I don't think the article mentioned installing longer springs but I may be wrong.
Old 12-03-2005, 11:30 AM
heres a lot of info, including a pic of the car you are talking about.
duckuscrapus
Old 12-03-2005, 12:51 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
duckuscrapus
after all these years, they still suck....
Camaro ball joint questions ModelAMan Suspension - Brakes - Steering 1 06-13-2005 02:03 PM
Front Ball joint ... PICTURE bg Suspension - Brakes - Steering 17 04-16-2005 01:24 AM
ball joint question RustBucketChevy Suspension - Brakes - Steering 4 11-06-2003 09:13 PM
Ball joint repalcement reborn55 Suspension - Brakes - Steering 3 06-13-2003 07:19 PM
79 Suburban Ball Joint change Help!!! mr_chickenhead Suspension - Brakes - Steering 2 01-09-2003 08:08 PM
