Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - ball joint taper reamer
Old 10-07-2004, 06:46 PM
poncho62's Avatar
poncho62 poncho62 is offline
Wiki Edits: 5
Most ball joints have the same taper......................if you are trying different splindles, it depends if you can adjust the alignment enough to compensate.
