ball joint taper reamer - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-02-2010, 03:30 PM
Originally Posted by johnsongrass1
68/69 was a SAE car and 70-79 were as well. 80 and newer used metric spindles.
SAE had nothing to do with the Imperial measuring system.
  #17 (permalink)
Old 07-02-2010, 08:13 PM
Originally Posted by tomslik
ok, so are the ball joint tapers the same from 67-79?
No. 70 to 81 is the same angle, but larger. The later ball joint is .080 too big to fit in the early A frame. You can turn down the later balljoint, or swedge out the Aframe.
