ball joint taper reamer - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-07-2004, 05:57 PM
3rdmember
anybody know what reamer i need for a 67-69 camaro balljoint and tie rod end?
are they the same taper as a 70-81 camaro?
trying to adapt something, i'll turn ya all on to it IF it works.
Old 10-07-2004, 06:46 PM
poncho62's Avatar
Wiki Edits: 5
Most ball joints have the same taper......................if you are trying different splindles, it depends if you can adjust the alignment enough to compensate.
Ontario Rodders
Old 10-08-2004, 07:05 PM
3rdmember
"Most ball joints have the same taper"
and that is...what?
Old 10-09-2004, 11:11 AM
willys36@aol.com's Avatar
Wiki Edits: 21
1 1/2"/ft.
See this.
Old 10-09-2004, 05:09 PM
3rdmember
seen 'em but it didn't say that the 67-69 camaro balljoint taper is the same as 70-up...
i know they're not the same part #.
anybody know for sure?
Old 10-11-2004, 10:52 AM
johnsongrass1's Avatar
Race it, Don't rice it!
68/69 was a SAE car and 70-79 were as well. 80 and newer used metric spindles.
Old 10-11-2004, 05:44 PM
3rdmember
ok, so are the ball joint tapers the same from 67-79?
Old 10-18-2004, 12:33 AM
Correct me if I'm wrong but the tapper your looking for is 6 degrees!
Old 10-18-2004, 01:54 PM
1.5"/ft actually ends up being 7.15deg. People have used 7deg taper (total angel -3.5deg per side) and it has worked fine.
Old 10-19-2004, 05:41 AM
3rdmember
well, just an update,. did find out that the tapers are the same, now just have to find a reamer cheaper that a 100 friggin' dollars...
Old 10-19-2004, 07:10 PM
I found this doing some diging. I have no idea if it is still good info but you can call and check.
I got mine from Chadwick Reamers 877-492-8249
85020 Taper 1.5"/ft. Range 7/16"-1". Spiral cut, 6 flute. 1/2" shank with hole and handle pin, 01 tool steel treated to Rockwell 60 hardness. $50.40.
85500 Taper 2"/foot. Range 3/8"-1-1/8". $70.88.
I have both and I'm happy with them. These are the best prices I was able to find.
I also found this
http://www.goodson.com/g5-bin/client...ID=&item=P5645
and this with no price listed
http://www.bcbroncos.com/shoptools1.html
I'm going to be buying one soon. I just need to be home during buisness hours...
Old 10-21-2004, 08:32 PM
I just bought it from this guy on ebay
http://stores.ebay.com/XKUT_W0QQsspagenameZl2QQtZkm
This is the description
THIS M2 HIGH SPEED #2 BALL JOINT & TIE ROD TAPER REAMER IS BRAND NEW AND MADE IN THE USA BY XKUT. 1 1/2" TAPER PER FOOT FOR MOST BALL JOINTS AND TIE RODS. OVERALL LENGTH IS 6 1/2". FLUTE LENGTH IS 4 1/2". LARGE DIAMETER IS 1". SMALL DIAMETER IS 7/16". SHANK DIAMETER IS 1/2". REAMER HAS 6 FLUTES. THIS TOOL CAN BE USED BY HAND WITH A TAP WRENCH OR IN A DRILL PRESS WITH A 1/2" CHUCK. MULTIPLE BIDS OF SAME OR DIFFERENT SIZES GET A FLAT FEE OF $3.85 USPS PRIORITY SHIPPING. SEE MY EBAY STORE FOR MORE TAPER REAMERS AND SETS.
Payed under $40 with shipping.
I also read and heard in my searching that SOME "bridge" or "car" (railroad) reamers will work but I didn't want to mess with it over a few $$$.
Old 01-02-2005, 03:46 PM
3rdmember
well, here's an update.
bought both bj reamers and the 1 1/2 is correct for pre 78 spindles and the 2 is for "metric"bj's(78-up)
i AM talking about chevelle spindles,for the record.
both of 'em set me back less than 80 bucks from XKUT..
thanks triaged for the tip!!!
Old 01-02-2005, 08:47 PM
Glad I was able to help. I have been driving my truck with my re-tapered ptiman arm for a while now. I tapered it on the truck with a 1/2" drill and ALOT of cutting fluid (I used some cheep "dark" cutting fluid from Home Depot - nothing special). If you don't get the speed and pressure just right it will chatter, but when you get it right it takes material off very quick and smooth. You will have to give it more pressure to start it but once it starts to cut you can let off and let the tool do the work for you.
I am sure the chattering is partally from the straight flutes and that using the $$$ stock car products one might work better and/or be easier to use...but for enlarging a taper that already exists (rather then tappering a plain hole) I think the much cheeper straight flute tool works well.
Old 01-03-2005, 05:17 AM
3rdmember
you're probably right about the straight flute thing but no more than i'll probably use it, it'll work fine.
