-   Introduce Yourself (http://www.hotrodders.com/forum/introduce-yourself/)
-   -   ball joints (http://www.hotrodders.com/forum/ball-joints-54949.html)
knuckles 12-28-2004 03:33 PM
ball joints
i have heard from a few pepole that the 73 to 88 c-10 spindle would bolt to a60 to 66 c- 10 truck . i have recently tried this and found the ball joints did not fit the spindle. is there a compatible ball joint i could use to remedy my problem? thanks
willys36@aol.com 12-28-2004 03:43 PM
Welcome. Being new to the site, you need to be sure to read the "Read Me' posts at the beginning of each forum. The ones here for example recommend that you just post a general introduction here and post tech questions in the appropriate tech forum, "Suspension - Brakes - Steering" in your case. This will give you the best chance for a good answer.
knuckles 12-28-2004 08:06 PM
thanks
thanks for the info i will direct my question over there
