ball joints - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 12-28-2004, 03:33 PM
knuckles's Avatar
New Member
Last journal entry: 1962 chevy
ball joints
i have heard from a few pepole that the 73 to 88 c-10 spindle would bolt to a60 to 66 c- 10 truck . i have recently tried this and found the ball joints did not fit the spindle. is there a compatible ball joint i could use to remedy my problem? thanks
Old 12-28-2004, 03:43 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Welcome. Being new to the site, you need to be sure to read the "Read Me' posts at the beginning of each forum. The ones here for example recommend that you just post a general introduction here and post tech questions in the appropriate tech forum, "Suspension - Brakes - Steering" in your case. This will give you the best chance for a good answer.
Old 12-28-2004, 08:06 PM
knuckles's Avatar
New Member
thanks
thanks for the info i will direct my question over there
