ball joints - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-28-2004, 08:09 PM
knuckles's Avatar
New Member
Last journal entry: 1962 chevy
ball joints
is there a compatible ball joint to mount a spindle from a 1985 c-10 to a1962 chevy truck...c-10.
Old 12-28-2004, 08:51 PM
Max Keith's Avatar
ball joints
The best thing to do is to contact a parts house and ask them for the part numbers for both ball joints on both trucks. If the numbers match, you are in luck.
If not, then that means you have to modify the spindle by having the holes taper drilled to match the C-10 ball joints. Im kind of curious about some other issues, like the spindle heights, and the ackerman arms. Are they both front stear or rear stear? Are the ball joint mounting holes the same distance apart on both spindles? what about the tierod ends?
Are the ball joints from the 85 longer than the ones for the 62? Are they shorter? Are the balljoint tapers the same? Larger or smaller?
Old 12-28-2004, 08:57 PM
packratwrecker's Avatar
Too many hobbies!
I have/had an article in Classic Trucks, I think, that told how to do just that.
If I can find it, I'll get you the month/year, so you can read it.
I can't find it. I'm sure it was back in 1998, on the "Six-pack To Go" project truck.
I loaned it to a buddy of mine, who wanted discs on his 65 1/2ton. I got it back, but seemed ot have misplaced it.
I think, but please research it, before you try it, that they used late model ball joints, on the early control arms. I don't remember what they did about the tie rod ends.
Old 12-28-2004, 09:42 PM
knuckles's Avatar
New Member
the only difference is the ball joints on the 62 are fatter than those on the 85 spindle, every thing else is the same
i will try the part numbers aNd see what happens
thanks for your help
i will check the magizine and see what i come up with
thank you for your help
Old 01-09-2005, 09:41 PM
knuckles's Avatar
New Member
ball joints
i changed out the whole crossmember control arms spindles etc..
everything lined up perfect and best of all cost me 65.00 bucks at the junk yard
