Ball Joints 64' Pontiac Bonneville - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-09-2011, 05:05 AM
UngerMarkus's Avatar
Tuck´n´Roller
Hi guys!
The upper and lower ball joints of my 64´ Bonneville are getting a little loose now. New ones are impossible to find, at least here in Europe. And the parts available on ebay are pretty expensive and of unknown quality.
Does anybody know if ball joints can be repaired? Is it possible, to drill the spot welds open and replace the teflon grommets inside, to get them back to propper condition?
Or maybe somebody knows if there are ball joints from other models that are suitable for adaption?
Markus
Old 06-09-2011, 08:02 AM
Wiki Edits: 27
old fix
There used to be a kit to pump in liquid plastic thru the grease zerk as a fix. It's been a lon time since I have seen the fix. The problem with the fix is it would only quiet them if minimal wear. if they had a lot of wear the ball joint could still come apart. mabe why I haven't seem the kits recently
Old 06-09-2011, 09:38 AM
Originally Posted by UngerMarkus
Hi guys!
Markus
The ball joints are not rebuildable, and you can't find the injectable plastic because that's a really bad idea. Get the complete front end kit from Kanter:
www.kanter.com
Old 06-10-2011, 06:02 AM
Tuck´n´Roller
thanks for the replies and especially for the link! I didn't know about kanter, i googled a lot for full size poncho suspension parts though. I just ordered a kit. Thanks! This helped me a lot!
Old 06-10-2011, 07:25 PM
Wiki Edits: 27
kantor parts
Kantor carries a lot of parts, and has always had good delivery, The prices are higher than a few other supliers. But kantor usually has everything in stock.
were can i get ball joints rtyauch301 Suspension - Brakes - Steering 6 09-02-2009 01:30 PM
Ball joints for MII? BobbyG-39 Suspension - Brakes - Steering 15 07-24-2008 04:40 PM
Ball joints... Rickrak77 Suspension - Brakes - Steering 5 10-26-2006 12:05 AM
ball joints knuckles Suspension - Brakes - Steering 4 01-09-2005 09:41 PM
ball joints knuckles Introduce Yourself 2 12-28-2004 08:06 PM
