Ball vs Stone Hone - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-07-2010, 03:53 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Ball vs Stone Hone
Hey everyone. I am gonna buy my first cylinder hone. What is the difference between a ball and a stone hone. I am putting new rings in my 305 and 350 so instead of hauling my blocks to the machinist i figured i would just buy the hone and learn to do it myself. Thanks in advance
Old 05-07-2010, 04:34 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
a stone hone can be used on many different size bore,where as a ball hone can only be used on alot smaller rage of sizes.
other than that, i cant tell you wich is better and why
i would be interested to hear what everybody has to say
i have a stone hone
Old 05-07-2010, 04:43 PM
Stone hones are only good if the bores are vertically-straight, like after boring. If you try to use it on a well used engine, after cutting the ridge, the stones won't make complete contact with the bore. Ball hones, since they're flexible, will conform to the bore, "scratching" the whole bore, whether it's perfectly round or not...just to help the new rings to seat. Cutting the ridge then ball-honing is a cheap way to overhaul the engine. If the bore wear is within tolerance, you could do it this way. It'll save you money in the short-term...but it doesn't beat boring/honing to the next size up for longevity.
Old 05-10-2010, 09:06 AM
Listen and Learn
Wiki Edits: 7
Alright thanks for the replies. Looks like ill end up getting a ball hone. What grit do you recommend and also a good company to buy from. I was looking at www.cylinderheadsupply.com Thanks
Old 05-10-2010, 09:22 AM
302 Z28's Avatar
A ball hone is really only a glaze breaker and does absolutely nothing to help straighten the bores. For a freshly bored cylinder a stone hone is the only way to go. If your after a quick shade tree rebuild use the ball hone then get rid of the engine or car.
Vince
Separating a stubborn lower ball joint taper Slipangle Suspension - Brakes - Steering 32 05-06-2013 02:07 PM
FYI. removing ball joints in Heidts A arms powerrodsmike Suspension - Brakes - Steering 5 11-11-2007 10:41 AM
Spindle interchanges bskaggs Suspension - Brakes - Steering 11 06-05-2006 02:29 PM
Front Ball joint ... PICTURE bg Suspension - Brakes - Steering 17 04-16-2005 02:24 AM
Ball Joints Question!!! bg Suspension - Brakes - Steering 2 03-31-2003 07:26 PM
