The engine I'm using is a 79 351W from an Ltd. It has the original Duraspark II components (distributor and coil) except I swapped in a new control module with the blue strain relief instead of the original one with two yellow. Do I need to install a ballast resistor with this system or run it with full 12V? I'm installing it into my 68 F100 that's had the pink resistor wire removed.
So if I read everything correctly it looks as though the module itself needs the full 12v but the coil needs a ballast resistor? Would it not depend on what coil you use? I found one wiring diagram (see attached) that shows no ballast resistor but it labels the coil "12v hi-performance coil". Currently I've installed the original 1979 coil but if I replace it do I have some coil options that would require or not require the ballast resistor? Also because the original 68 F100 pink resistor wire on my truck was snipped off at the ignition switch and replacement would be too difficult could I use any of those ceramic ballast resistors you see mounted to fenders and firewalls? Are all ballast resistors similar? conversion
Okay, I think I'll source a coil with internal resistor that will fit in the current location (sitting vertical). That would likely be the easier to do.
yup. MSD makes a duraspark II pigtail for the 6 boxes. Gut the housing, mount a GM HEI module in it ( aluminum housing is great for cooling ). wire the Duraspark connector to it, and make it plug and play
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
