Band type exhaust clamps - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-01-2010, 09:28 PM
roger1's Avatar
I've never used these band type clamps before.
How well do they work as far as sealing and the ability to get the pipes back apart again after removing the clamps?
I was looking at 2 different types.
These:
Dynamax Clamps
And these:
SuperTrapp Clamp
Old 12-01-2010, 10:23 PM
The mobile view is crap
I have never used them clamps before but we use these at work for joining round tubing together http://www.morriscoupling.com/prod1.html we use a lot of 4 bolt clamps and I doubt you would be able to pull the clamps apart with each end of the joined pipes together with 2 4 wheel drive trucks pulling on them. These clamps also have rubber inside of them for sealing purposes.
Old 12-01-2010, 11:00 PM
ericnova72's Avatar
More for Less Racer
These style of clamps work excellent, seal good on clean pipe, don't crush or indent the pipe at all, so removal and seperation is super easy. They are the way to go
Old 12-02-2010, 04:15 AM
They look like a super clamp,
but, won't the gasket melt on a tailpipe installation?
Old 12-02-2010, 04:18 AM
Old 12-02-2010, 06:14 AM
bondo's Avatar
Ayuh,... The Morris clamps are for compressed Air, not exhaust...
I've been using the Dynaclamp style for Years...
I'll Never use an old bar, 'n saddle clamp again...
Old 12-02-2010, 07:10 AM
roger1's Avatar
Thanks guys.
I messed up my original link on the SuperTrapp clamp.
What about this style? It is more narrow as compared to the Dynamax clamp. Which style is better to go with?
SuperTrapp clamp
Old 12-02-2010, 02:50 PM
ericnova72's Avatar
More for Less Racer
I've not used the Supertrapp clamp, but it doesn't look wide enough to hold two pipes end-to-end?? Looks more like it is for holding a pipe that is split 4, 6, or 8 ways clamped over another pipe?? Seems like the Supertrapp mufflers have that type of slip fit over a pipe split connection on them??
Old 12-02-2010, 03:28 PM
Band clamps are better then sliced bread.
Old 12-02-2010, 04:00 PM
roger1's Avatar
Thanks, that makes sense. I'll go with the wider Dynamax clamps.
Exhaust manifold modifications for a 403 bandit79jun Engine 8 02-25-2010 09:41 AM
I lose compression w/ valve adjust drivehard Engine 5 11-23-2009 09:29 AM
Exhaust tips CrazyRoyExhaustfreak Engine 0 10-29-2006 06:04 PM
Exhaust System Sizing leejoy Engine 9 10-04-2006 07:38 PM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
