-   Garage - Tools (http://www.hotrodders.com/forum/garage-tools/)
-   -   bandsaw question... (http://www.hotrodders.com/forum/bandsaw-question-177015.html)
cutthroatkid 04-27-2010 10:12 PM
bandsaw question...
Well I had a metal bandsaw awhile back but nomore,now I need another I see wood bandsaws pretty cheap&I saw something about there's s pulley to convert it to a metal bandsaw.Has anyone heard of this?
justold 04-28-2010 05:50 AM
Yes you can use a wood band saw to cut metal . You have to change the drive pulley to slow it down if it doesn't have a step pulley on it . If you are cutting shapes it will be fine , otherwise I don't think you will be happy with it .
BOBCRMAN@aol.com 04-28-2010 06:01 AM
Most real hardware stores have selections of pulleys. I have one on an old "Delta" works great.
302 Z28 04-28-2010 07:47 AM
I have an old Sears table top band saw, and I was able to purchase a different pulley and shorter blade for metal cutting. It works great as long as you don't get in too big of a rush.
Vince
evolvo 04-28-2010 11:16 AM
There's a thread over on the HAMB about using a motor and rheostat out of an old tread mill exerciser. Sorry, couldn't find it quickly. Long and short is that the tread mill motor replaces the wood saw motor and gives you infinite speed adjustment.
Makes me wish I hadn't passed on that $50 wood band saw last summer!
Old Fool 04-28-2010 12:58 PM
Wood cutting bandsaws have a blade speed of about 3000 fpm.
Metal cutting band saws have a blade speed of less than 400 fpm.
302 Z28 04-28-2010 01:18 PM
A rheostat is not what you want to do to slow the bandsaw down. If you had an actual variable speed drive so the torque remained the same that would be the way to do it.
Vince
evolvo 04-28-2010 06:07 PM
You have to adapt the whole variable speed system from the tread mill to the band saw. That means the motor and all associated electronics not just the rheostat.
timothale 04-28-2010 10:51 PM
saw conversion
I had an 18 in band saw that had a jackshaft system , just move the belts to different pullies, metal chips can build up, especially when using wax when cutting aluminum. . adding brushes to keep the wheels clean helps.
Irelands child 04-29-2010 05:21 AM
I use my little hobby Sears to cut aluminum regularly and it works just fine. All I have to do is remember to clean the drive wheels after each use. This one is direct drive so can't use it for steel, so I use my Bosch jig saw with fine down cut blades (if I can find them) on slow speed to do that.
Dave W
