bang boom - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-22-2005, 07:15 PM
Redman Racing
bang boom
I got a stock 8.5 open 3.73 in a 85 olds cutlass 442
I stuck a chevy 350 in there with about approx 400+hp
anyone think i will have problems with 8 inch slicks
no trans brake
3000 stall
probaly brake the stock u-joints first i think they are already on the way
Old 03-22-2005, 07:38 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
no trans brake
3000 stall
The 8.5 should hold up to the 350 no problem, the slicks are another thing.
I would recommend pulling the axleshafts out of the rear, clean them really good and paint a straight line the length of the shaft, check them periodically and replace when they twist more than turn.
Also check the preload of the pinion, and backlash to make sure they are within spec's. Run it til it dies.
Old 03-22-2005, 09:21 PM
The slicks indicate to me that you will be racing? If nothing else, I would consider the poor guy in the other lane (or in the stands) while you're putting down atf under your tires shortly after your "U" joint leaves. He may also be surprised when your car leaves the line, breaks an axle, runs over the tree, and t-bones his car.
Nothing is cheaper or safer then showing up to race with the right equipment the first time. This typically takes a few years to sink in so if this aint good advice now, it will be when you're ready.
Old 03-23-2005, 07:27 PM
Redman Racing
thanks for the advice i should look into saftey for others and myself before speed for me
What is George Bush's Real IQ? NAIRB Off-Topic 98 09-03-2006 02:04 PM
Best bang for the buck... virrix Engine 9 10-16-2004 07:52 PM
Which is the best bang for you buck? toddtheodd Engine 6 05-23-2004 06:10 PM
what would you do ???????? funny Stitch Hotrodders' Lounge 7 01-31-2004 02:52 AM
Best bang for the buck? Dubz Engine 7 12-28-2003 03:47 PM
