Banging noise coming from back of the 1958 Lincoln while turning. - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-27-2009, 11:48 AM
Pudycat
Look for the simple solution first. One time I had a nasty noise when moving on a motorcycle and I thought the worst (transmission etc). It turned out to be a bolt came loose and let a drive shaft cover hit a u-joint. I had myself all worked up over a very little thing.
  #17 (permalink)
Old 02-27-2009, 01:09 PM
Big Don's Avatar
58 linc
If the car is original, then does it not have multi-leaf springs in the rear?
LOUD POP! noise when turning right in S-10 cknox88 Suspension - Brakes - Steering 3 01-12-2005 07:31 PM
Lincoln air ride on back of 57 chev truck? murrsue Suspension - Brakes - Steering 1 12-10-2004 02:09 PM
Fuel coming back up through EGR plate/valve.....car died......whats goin on here? Steve-0321 Engine 2 10-17-2004 07:14 PM
DeSoto, coming back? 38 special Hotrodders' Lounge 11 04-28-2004 05:30 PM
exhaust coming back through carb echauer Engine 5 11-24-2003 10:18 AM
