Banging noise coming from back of the 1958 Lincoln while turning.
I finally am getting back to working on my Lincoln and was wondering if anyone on this board might have any idea what the banging noise coming from the rear of the car could be. It shifts, drives and rides fine. It only does it when going around corners, the car does not sit quite right because the right of the car sits lower on that side. Could it be the spring is out of the pocket?-Alex.
I would raise and support the rear and give the rear tires a spin and listen for spider gear noises. And like you eluded to, check your springs and mounts while you're at it. . . . "Dollars are like votes, except that they actually count." |
my mother in law called me and wanted me to take a look at her car said every time she went around a corner she would hear a thump so i took it for a spin and sure enough i heard the same thing sounded like it was coming from the trunk so i stopped and looked and sure enough the 4 way lug wrench she carried was sliding back and forth LOL!!
[QUOTE=burnt olds]
Type:Semi-Floating. Gear type: Hypoid. Gear Ratio: 2.87 to 1 Drive Gear-(Ring Gear): 43 Diameter: 9.25 in. Face Width: 1.38 in. Number of Teeth Pinion: 15 Differential: Type: 2 pinion Bearings: Tapered Roller. Bearing Preload: By Shim. Pinion Backlash(Variation Gear Set): Maximum: .008 Minimum: .003 Drive Gear Runout- Maximum: .002 Pinion Bearing Adjustment: Without Seal: 8-12 in. lbs. With Seal: 10-20 in. lbs. Differential Side Thrust Washers- Thickness: .030-.032 in. Pinion Gear Side Thrust Washers- Thickness: .030-.032 in. Wheew! That took awile, couldn't find if it's Posi or not, maybe someone can understand any thing I typed. Maybe by reading this someone can tell if it's Posi.And yes, newer tires, same size. |
Do you have this on your rear face bar?
Yeah, I forgot about that.
Where did you find that picture at?
What do spider gear noises sound like? |
Thanks, I'll try it. I wasn't sure what it was, thought maybe it was something that needed replaced internally, thanks for clarifying.
You should change the rear lubricant, refill and add this. Drive it for a few days doing tight turns. If it doesn't calm down, it will have to be redone.
Sounds good, will try it in the next few days when I get back from the Kansas City area.
| LOUD POP! noise when turning right in S-10 | cknox88 | Suspension - Brakes - Steering | 3 | 01-12-2005 07:31 PM |
| Lincoln air ride on back of 57 chev truck? | murrsue | Suspension - Brakes - Steering | 1 | 12-10-2004 02:09 PM |
| Fuel coming back up through EGR plate/valve.....car died......whats goin on here? | Steve-0321 | Engine | 2 | 10-17-2004 07:14 PM |
| DeSoto, coming back? | 38 special | Hotrodders' Lounge | 11 | 04-28-2004 05:30 PM |
| exhaust coming back through carb | echauer | Engine | 5 | 11-24-2003 10:18 AM |
