banjo bolt torqu - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-31-2008, 08:49 PM
banjo bolt torqu
What is the torque on the banjo bolt on ford brakes? Is it 20?
Old 02-07-2008, 09:09 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Probably about that. I have always tightened them 'pretty snug' - go by feel of the shims deforming a little. Never torqued them.
Old 02-07-2008, 04:24 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
What Willys said...plus they are just like any other type fitting in that if you overtighten them they will sometimes leak.
Old 02-07-2008, 06:06 PM
Wiki Edits: 27
bolt torque
If i don't know I check the reference tables in one of the 100 repair manuals in the shop.. they have a list of bolt sizes and recommended torque for each sige and grade of bolt.
Old 02-07-2008, 06:25 PM
Lost in the 60's
Wiki Edits: 4
Yes...but that is for standard type bolts......a banjo fittings bolt is not standard, plus the fact that it compresses two copper or aluminum washers against a brass housing....well you can see that you do not want a lot of torque, just good and snug will do.
Old 02-07-2008, 08:15 PM
Wiki Edits: 27
opps
I didn't read enough and was thinking of the banjo rear end housing or mabe my brother strumming his banjo with his remaining 3 good fingers
Old 02-07-2008, 08:22 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
On a GM metric caliper the torque spec is 32 ft. lbs. for the banjo bolt.
Old 02-08-2008, 08:05 AM
Wiki Edits: 21
He doesn't have 2 rotten teeth left, look like he is missing a few key chromosomes, sit on the front porch and play 'Dueling Banjos' when any strangers walk by does he?
Old 02-08-2008, 09:28 AM
Wiki Edits: 27
he is a good guy
He had the most points scored at that time by a high school basket ball player... he had a full ride college scholarship for football and basketball ...uncle sam had other plans for him ...The US army put him in the radioactive zone right after we dropped the bomb on japan. HE was a contractor in CAlif and the gas company turned on the gas in a new home his crew had just finished. when he opened the door and walked into the living room the house exploded and blew him right thru the front picture window. one year in the hospital . today he has lost most of his eyesight and hearing. has an appartment a block from the VA hospitay. says he can walk there faster than what it takes to get an ambulance. he still can play a mean banjo with his remaining 3 good fingers. not enough good fingers to play a piano or pick a guitar any more
Old 02-08-2008, 02:59 PM
Wiki Edits: 21
Wow! Sorry about the joke, I thought you were kidding. If it weren't for his bad luck, your brother would have no luck at all.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 07:57 PM
Change 8 bolt front hubs/rotors to 6 bolt? (gm 3/4 ton) murrsue Suspension - Brakes - Steering 3 04-02-2007 02:05 PM
Best ways to straighten a twisted repro door? Ripped Body - Exterior 13 07-04-2005 08:29 AM
I need a banjo bolt for 9 inch rearend alf51chevy Suspension - Brakes - Steering 5 04-02-2005 10:33 AM
10 bolt to 12 bolt 1980Impala Transmission - Rearend 8 04-25-2004 05:48 PM
