banjo fitting leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2011, 05:28 PM
banjo fitting leak
I've got a leak problem with flexible brake lines with banjo fittings that attach to the front calipers. Even though I've installed the new copper washers on both sides of the fittings, and tightened them down, I have a very small leak on both front calipers. The calipers are rebuilt mid-80's GM (Monte Carlo), and new brake lines. This set-up is a disc brake conversaion on my 1948 Plymouth. The leak is very small, but it's there. Anyone have a similar problem? Thanks.
Old 02-18-2011, 06:14 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Are you sure you have it tight enough ?
Cole
Old 02-18-2011, 06:19 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
the copper seal washers may be too thin and the bolt bottoms out before enough force is applied to the sealing washers. Try and get some thicker ones.I have had this happen before.
Old 02-18-2011, 06:21 PM
I didn't use a torque wrench, just a 3/8" breaker bar and a 10mm socket. But I did make them pretty tight. I was a little concerned about the banjo bolt being drilled in the center to allow fluid flow. Any idea what proper torque should be for these bolts? I know they are metric, but the threads looked very close to a regular 3/8" bolt.
Old 02-18-2011, 06:30 PM
eloc431962's Avatar
Wiki Edits: 37
On a GM metric caliper the torque spec is 32 ft. lbs. for the banjo bolt. But you might want to think about what latech said if it don't work going by the specs, I have had to go to a thicker washer before also.
Cole
Old 02-18-2011, 06:41 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Here's a link from a search on this board, others have had the same issue...
Brake leaks driving me crazy!
46 banjo in a 31 A v-8 texas webb Transmission - Rearend 7 12-16-2010 05:38 AM
AN Fitting Leak nova69 Engine 3 06-04-2008 08:46 AM
trans cooler fittings.. 3/8 hose fitting to a AN fitting? scapegoat Transmission - Rearend 6 04-14-2008 04:12 PM
Banjo fitting illegal?? gavinpierce Hotrodding Basics 10 04-22-2006 10:08 AM
Banjo Wheel ThirtyNine Body - Exterior 2 11-23-2002 07:48 PM
