Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Banjo fittings on Mustang 2 calipers
Old 03-08-2012, 07:55 PM
62restomod 62restomod is offline
I'm in the process of plumbing and servicing the brake system on my 34. I found that the neck of the banjo fitting interferes with the caliper housing on the M2 brakes. I can grind a notch in the housing to accomodate the fitting but I wondered if anyone else encountered this with pre made SS lines.
Also, using the standard pump & hold method, I'm not moving much, if any, fluid to the rear brakes to bleed them. Could it have anything to do with the 10psi residual pressure valve. Yes, I double check to make sure I installed it correctly.
Thanks
Bud
