Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Banjo fittings on Mustang 2 calipers
Old 03-09-2012, 07:57 AM
speedbump speedbump is offline
The SS lines I used had a slight angle on the banjo fitting. Put it on one way and it hit, the other way(upside down) and it worked OK. The RP valve lets fluid go, uninterupted TO the wheel cylinder, it takes 10 lbs pressure to let it go back to the MC. That's not your problem. Sometimes you need to bench bleed those MC's in order to keep them from pushing and pulling an air bubble when you pump the pedal. A Phoenix or MityVac will overcome that problem because the fluid only moves in one direction without the aid of the MC.
