banjo rearend - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2006, 11:28 AM
banjo rearend
I'm trying to build a classic rat. How much will the banjo rearend handle??? I want to keep the old spring over rear end for a classic appearance but I've got a 460 to put in it and I don't know what the old banjo will handle
Old 04-04-2006, 11:50 AM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
banjo rearend
You might be able to use it if you use an auto trans and be the last to leave the stoplight. I had a friend who used to regularly take out the rear end in his 46 coupe with a mild 283. Go for a Ford 9 inch. You'll be much happier.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
I need some input on putting a Ford rearend under a 1972 Dodge Dart onebadmerc Transmission - Rearend 7 12-21-2005 10:30 PM
Hotrodders Knowledge Base: Transmission - Rearend Jon Transmission - Rearend 0 11-26-2005 06:23 PM
I need a banjo bolt for 9 inch rearend alf51chevy Suspension - Brakes - Steering 5 04-02-2005 09:33 AM
assembly diagram for a Banjo type rearend teched Transmission - Rearend 3 12-14-2004 01:51 AM
