Bare Metal Prep?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-23-2006, 09:54 AM
camaroman7d's Avatar
Bare Metal Prep??
Here's the situation. I stripped my car to bare metal several weeks ago (couple months). I used chemical stripper, there is very little flash rust on the car and I plan to sand the whole car again before laying down the epoxy primer. My question is what should I use to wipe the car down before I start sanding? I want to make sure I get rid of all the chemical stripper residue. In the past I would have just used laquer thinner but, since I am using epoxy primer and the surface prep is so critical, I don't want to take any chances. I'll be heading to the paint store in a little while and would like to have a little info. Of course I will use wax and grease remover but, is there something else I should use first?
If it matters the primer I bought is SPI.
Old 09-23-2006, 10:51 AM
adtkart@aol.com
I would make sure that I cleaned it with W&G remover and go from there. Normally, if there is stripper left on the metal, it will rust fairly quickly, from my experience with the stuff.
Aaron
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 10:45 AM
Metal Finishing, let's talk about it. MARTINSR Body - Exterior 29 04-19-2011 09:47 PM
Bare metal prep greenmachine Body - Exterior 7 10-27-2004 07:57 AM
Bare Metal Prep PPG 68NovaSS Body - Exterior 3 09-06-2004 07:00 PM
Bare metal prep 72novaproject Body - Exterior 2 12-19-2002 02:15 PM
