barley any oil to the top of the heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-20-2012, 10:20 PM
hi. i have a 2000 pontiac grand prix gt with a 3800 series 2 v6 (not supercharged). it just started a low knockin sound. if u let it set and cool down it stops knockin until it runs for a min then itll start again. so i took the valve cover off of the front closet to the radiator thats where the knocks coming from. i started it upwith it off and it didnt shoot any oil out. could it be the oil pump gettin weak? there was barley any oil settin in the top of the head.
Old 05-20-2012, 11:08 PM
DoubleVision's Avatar
Doubtful on the oil pump. More than likely the noise you hear is one of the roller lifters which tend to make noise and not pump much oil up when they get trash in them. This is a rather common problem in the late 80's to late 90's sbc line of engines. All I do is wait until the next oil change, pour a half can of sea foam into the oil, start the car and let it run for 20 minutes, then proceed with the oil and filter change. usually when I fire it back up in most cases the noise is gone. If the noise did not improve I would let it ride and just live with the noise as it's really not going to cause any damage.
No oil to top end of '94 Dyna joy4himmorgan Engine 3 01-05-2011 07:39 AM
no oil in top end of pontiac 400 1ijoey Engine 3 02-09-2010 11:16 AM
Oil to top end (passenger side) lt1bbody Engine 13 05-03-2005 02:23 PM
new rebuild no oil getting to top end. Edelbrock350chev Engine 11 12-29-2004 04:03 PM
Top Line heads western star Engine 15 07-14-2004 11:01 PM
