Barry Grant Carb Help
Hey guys, I recently acquired a 67 Nova that was set up for the track, and I am in the process of making it more streetable. It has a Barry Grant 800 Carb on it. Right now the jets in it have been bumped up to I believe 78. I have been searching to find specs on my carb to find what the stock jetting was so I can get them in and have a starting point for tuning, i cannot find anything on the carb at all and i don't have a model #. Below is a pic to help identify. Thanks!
http://i1114.photobucket.com/albums/...-46-24_581.jpg |
Take the bowls off and look at what you have for jets and power valves.If you have a problem,what is it?why are you changing anything?Do you or someone you know have a jet board(spare jets)
Also i do not have access to a jet board. |
make sure your static timing is 16 degrees or so at idle.what coil are you using? I dont see a multi spark unit in your photo?what cam are you using?
when changing jets,go up or down 2 sizes at a time until fine tuning. |
Barry Grant Carb help
Here is the website for Demon carburetors. Click on Tech Support. Demon Fuel Systems - Tech Support
It says: BG 477983 11586 Thanks! |
Barry built custom Holleys for racing !!! What you have is a custom built Holley by Barry Grant Built around the engine for max performance.
Changing jets wont match the engine build or Idle normal to that cam and compression some builds Idle at 2500 rpm and some at 600rpm perticular to the build. The jetting and power valve are set for the characteristics of that particular eng. unless some one bought it and put it on that eng that it wasn't set up for!!! His Holleys were great performing carbs he knew his stuff! your lucky to have one!!! Jester To make it more streetable you may want to start with a cam change and then tune the carb in! |
4779 is a holley 750.It does look like a holley carb.BG carbs use a.n. fittings
Whats the blue print on the engine? Surly you have the print? The 4779 is the holley # hand etched its a 750 modefied! as vinny posted
Jester |
The holley choke horn has been milled off thus you have an increase in CFM as you were told by the last owner stating it was 800 it actualy may be more!!!The Holley list # was on the horn Thats why he etched it on the carb! Barrys a member on this forum or was there have been many changes in the last few months you might try to private message him or maybe he'll see your thread and chime in.
Jester |
I called a few other carb builders in detroit and received some good info on the #s and the jets. original jets were #74 prim & #84 sec.
The scribed # of #4779-S3 There never was a #4779 8-3! There were 3 stages #4779S1 ,#4779S2 ,and #4779S3 The S1 was a reworked 750 with the chock horn intact.flowed about 800 for sportsmen class just had a little work. The S2 was a reworked 750 with the chock horn milled off and flowed about 850 The S3 Which you have is a horn off radius ed and flowed with jet tubes a completely reworked drag carb that flows well over 950 CFM The other #'s are inconsequential I hope this helps you know what you have:thumbup: Jester |
PJ are the venturis ported?
Jester |
There was 1 more B.G. Holley its number was 4779S with no #'s after the S, That one is a check legal sportsman class carb.
Jester I just found it here with more info you may like to see on the B.G. Holleys 4779S's http://www.chevelles.com/forums/showthread.php?t=212629 |
for tuning on the street it is VERY IMPORTANT to tune with the pvcr's for WOT and jets ONLY FOR CRUISE. So many people think the jets are for WOT and they ARE NOT.
| All times are GMT -6. The time now is 01:01 PM. |
