Barry Grant Carb Help - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-21-2012, 08:46 AM
Daubers's Avatar
Apprentice
Hey guys, I recently acquired a 67 Nova that was set up for the track, and I am in the process of making it more streetable. It has a Barry Grant 800 Carb on it. Right now the jets in it have been bumped up to I believe 78. I have been searching to find specs on my carb to find what the stock jetting was so I can get them in and have a starting point for tuning, i cannot find anything on the carb at all and i don't have a model #. Below is a pic to help identify. Thanks!
Old 09-21-2012, 08:58 AM
vinniekq2's Avatar
Take the bowls off and look at what you have for jets and power valves.If you have a problem,what is it?why are you changing anything?Do you or someone you know have a jet board(spare jets)
Old 09-21-2012, 09:31 AM
Daubers's Avatar
Apprentice
I will confirm tonight, I was told they were 78's. Right now it is simply getting too much fuel dumped in, and get's prominent as I adjust the timing. Would like to get it down to a nice idle, not needing 1600 rpms to keep it from stalling out.
Also i do not have access to a jet board.
Old 09-21-2012, 09:36 AM
vinniekq2's Avatar
make sure your static timing is 16 degrees or so at idle.what coil are you using? I dont see a multi spark unit in your photo?what cam are you using?
when changing jets,go up or down 2 sizes at a time until fine tuning.
The Following User Says Thank You to vinniekq2 For This Useful Post:
Daubers (09-21-2012)
Old 09-21-2012, 09:44 AM
Barry Grant Carb help
Here is the website for Demon carburetors. Click on Tech Support. Demon Fuel Systems - Tech Support
The Following User Says Thank You to cdminter59 For This Useful Post:
Old 09-22-2012, 03:19 PM
Daubers's Avatar
Apprentice
Thanks for the link, but it is not a Demon carb, its older than that. On their site you have to chose what model is on the carb and mine does not have one, it only has hand engraved numbers. Anyone know of any reference to decipher them to know what I have?
It says:
BG
477983
11586
Thanks!
Old 09-22-2012, 03:53 PM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
Barry built custom Holleys for racing !!! What you have is a custom built Holley by Barry Grant Built around the engine for max performance.
Changing jets wont match the engine build or Idle normal to that cam and compression some builds Idle at 2500 rpm and some at 600rpm perticular to the build. The jetting and power valve are set for the characteristics of that particular eng. unless some one bought it and put it on that eng that it wasn't set up for!!!
His Holleys were great performing carbs he knew his stuff! your lucky to have one!!!
Jester
To make it more streetable you may want to start with a cam change and then tune the carb in!
The Following User Says Thank You to painted jester For This Useful Post:
Daubers (09-23-2012)
Old 09-22-2012, 04:03 PM
vinniekq2's Avatar
4779 is a holley 750.It does look like a holley carb.BG carbs use a.n. fittings
Old 09-22-2012, 04:06 PM
Whats the blue print on the engine? Surly you have the print? The 4779 is the holley # hand etched its a 750 modefied! as vinny posted
Jester
Old 09-22-2012, 04:19 PM
The holley choke horn has been milled off thus you have an increase in CFM as you were told by the last owner stating it was 800 it actualy may be more!!!The Holley list # was on the horn Thats why he etched it on the carb! Barrys a member on this forum or was there have been many changes in the last few months you might try to private message him or maybe he'll see your thread and chime in.
Jester
Old 09-22-2012, 05:43 PM
I called a few other carb builders in detroit and received some good info on the #s and the jets. original jets were #74 prim & #84 sec.
The scribed # of #4779-S3 There never was a #4779 8-3!
There were 3 stages #4779S1 ,#4779S2 ,and #4779S3
The S1 was a reworked 750 with the chock horn intact.flowed about 800 for sportsmen class just had a little work.
The S2 was a reworked 750 with the chock horn milled off and flowed about 850
The S3 Which you have is a horn off radius ed and flowed with jet tubes a completely reworked drag carb that flows well over 950 CFM
The other #'s are inconsequential I hope this helps you know what you have
Jester
Old 09-22-2012, 05:50 PM
vinniekq2's Avatar
PJ are the venturis ported?
Old 09-22-2012, 06:04 PM
Vinnie he may not know what ported venturie's look like? Unless you know his ability ?
Jester
Old 09-22-2012, 07:45 PM
There was 1 more B.G. Holley its number was 4779S with no #'s after the S, That one is a check legal sportsman class carb.
Jester
I just found it here with more info you may like to see on the B.G. Holleys 4779S's
http://www.chevelles.com/forums/showthread.php?t=212629
Old 09-22-2012, 07:50 PM
Banned
for tuning on the street it is VERY IMPORTANT to tune with the pvcr's for WOT and jets ONLY FOR CRUISE. So many people think the jets are for WOT and they ARE NOT.
carb, timing
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
which Barry Grant carb 1934chevycoupe Engine 3 11-20-2006 06:55 AM
Barry Grant Demon carb gilby246 Engine 4 03-24-2005 12:12 PM
barry grant carb ??? k-star Engine 3 06-18-2004 07:42 AM
barry grant carb ??? k-star Engine 1 05-19-2004 05:14 PM
barry grant carb cjhutch02 Engine 2 12-22-2002 12:54 PM
