Barry Grant carb ID Older model - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2011, 11:57 AM
dlink2006's Avatar
Hi: I would appreciate any help you might have in identifying this Barry Grant carburetor. Trying to figure out cfm. It is a mechanical secondary dual feed 4-bbl. It has green removable venturis. It doesn't look like the demon series carbs. I could send pictures to an email address. model number is 7282010 GP engraved on small pad on outside of secondary part on main carb body on linkage side.Thanks
Old 07-22-2011, 02:36 PM
Heres how to decipher your Demon, except they dont list a 7 as a first digit. GC stands for general competition carb. Looks to be a 650 or 750 gasoline version.
http://barrygrant.com/demon/default.aspx?page=3
Old 07-22-2011, 04:03 PM
dlink2006's Avatar
Demon decode
Thanks but this is not a Demon. I think it is older than that.
Old 07-22-2011, 08:59 PM
Even if your carb was made before they started using the Demon name, the series numbers still apply
7-series, or model of carb(are you sure this is a 7 and not a 1)
28- Venturi diameter-Green-1.280"
2-Butterfly Dia-1 11/16" dia.(what size are yours?)
01-Booster style-Down leg
0-Fuel type-Gasoline
GC-Factory prep.-General Competition(single four barrel)
If your first digit is a 1, then the carb is a 650cfm
Old 07-22-2011, 10:32 PM
dlink2006's Avatar
It is possible that the 1st number might be a 1 it was done with an engraver so the numbers are not perfectly clear. It has 1-11/16 pri & secondaries. I was told this carb came off of a 455 Olds. It has removable venturis. I saw a demon carb that had the venturis changed from green to red to increase the cfm. Do you know if that is possible with this carb. If this is a 650 cfm do you think it will actually flow more than 650 cfm? I just thought it must be bigger to run on a 455. This thing has bowls more like a holley than any of the demon carbs. I havent been able to find one like it that has the removable venturis. Thanks for your help I spent a lot of time on the internet trying to figure out what this was.
Old 07-22-2011, 10:43 PM
Red venturis(1.40") is one of the changes needed to flow 750cfm, there are other changes to idle air bleeds, high speed air bleeds, squiters, etc.
Look at BG's web page, all the info is there under specifications.
Old 07-22-2011, 10:53 PM
dlink2006's Avatar
Thanks for your help.
Old 07-23-2011, 01:17 PM
dlink2006's Avatar
Does anyone out there have a set of red (1.40) Barry Grant venturis sleeves they would trade for green ones or sell, or know where I could buy them?. I need Pt#127402. Thanks
Old 07-23-2011, 03:39 PM
How quick do you need them? BG will be back open sometime this fall.
Old 07-23-2011, 08:56 PM
dlink2006's Avatar
Barry Grant Carb
I put a couple of pictures of this carb in the photo gallery. I will wait on the sleeves unless someone has a set.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
which Barry Grant carb 1934chevycoupe Engine 3 11-20-2006 06:55 AM
Barry Grant Alky Carb bigaldart Engine 13 09-07-2006 07:27 AM
barry grant carb ??? k-star Engine 3 06-18-2004 07:42 AM
barry grant carb ??? k-star Engine 1 05-19-2004 05:14 PM
barry grant carb cjhutch02 Engine 2 12-22-2002 12:54 PM
