Barry Grant Vintage Tri Power - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-06-2008, 01:39 PM
I purchased the Barry Grant vintage tri power set up for my Model A hot rod. engine is a 327 SBC with 7000 miles. Swap went OK, fired engine and RPM's went like it was on the way to wide open throttle, so I shut it off. I checked everything again (vacuum lines, retighted intake bolts, etc. All throttle linkage is where it should be) tried it again, same thing. Major RPM,s on start up. It has to be a big vacuum leak, but I don't know where it's coming from. Anyone have any ideas? I had a performer manifold on the engine before, had no issues with it. I have used SBC's in all the cars I've built, some engines with more than one carb but I've never had one that revved out like that on start up.
Old 07-06-2008, 02:30 PM
Even under a no load condition it cannot rev "like it was on the way to wide open throttle" on just air. It has to be getting gas also.
Old 07-06-2008, 02:47 PM
techinspector1's Avatar
Wiki Edits: 326
http://www.crankshaftcoalition.com/w...ak%2C_internal
Old 07-06-2008, 02:59 PM
Inspector, what you linked is good info, but in this case, there has to be fuel to go with the air to cause the runaway rev. I would tend to look to see which carb is malfunctioning first.
Trees
Old 07-06-2008, 03:21 PM
If you guys think it might be a fuel problem, I'm using a GM mechanical fuel pump, the floats are showing halfway in the sight gauges (Barry Grant spec). I'm not using a fuel pressure regulator, have one that I could install, will try it next. The setup I have is on Barry Grant.com (complete install instructios).
malc's Avatar
Living At The Speed Of Life
The manual says,
"Won’t Idle Down Reset throttle plates, check idle-mixture screws, lower
float levels, check initial timing, check throttle linkage,
check for vacuum leaks"
and,
"Won’t Stay Running Below 1500 RPM Reset throttle plates, check idle-mixture screws, lower
float levels, check initial timing"
Old 07-07-2008, 12:59 AM
4 Jaw Chuck's Avatar
Might want to check the manifold gasket, it may have slipped allowing air into the engine from the valley side.
Yea...its happened to me.
Old 07-07-2008, 09:34 AM
Technical Support Barry Grant
You may need to close the butterflies on the outer carburetors if you have not already done so. On the baseplate there is a small black allen set screw to be able to achieve this. Try closing the outers completely and setting the idle speed with the center carburetor.
Bbc Tri Power crossfire84 Engine 5 07-20-2012 02:21 AM
Barry grant carb air/fuel question Ratoflic Engine 8 05-10-2005 05:51 PM
SB Tri Power on Vets roys63 Engine 5 11-17-2002 06:03 PM
Tri power spam on e bay DragLinkscc Hotrodders' Lounge 0 05-10-2002 08:56 AM
1961 chev Impala bubble top 348 tri power David McConnell Engine 3 11-08-2001 12:31 AM
