Base And Clear - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-19-2003, 06:17 AM
PAS55's Avatar
Question Base And Clear
I am doing my car in base clear . I have a design worked out which will take me a while to lay out. All of the base coats say the clear must be applied within 24 hr. What can you do if the clear can't be applied within the 24hr.
Garry
Old 09-19-2003, 06:39 AM
Madd Syntst's Avatar
Returning American Maddman
How much extra time are you talking about? A lot of the cure/dry time has to do with weather conditions as well. is it hot, cold, dry, humid, etc. I've gone past 48 hrs before with no real worries.
Old 09-19-2003, 10:48 AM
Dragon J's Avatar
Last journal entry: Harley/Fire
As stated, you usually have a short 'window' of opportunity to do graphics- that's why I prepare everything ahead of time, sleep well a few days before, then 'burn the midnight oil' and do it all in the 'window' to assure good results!! Check spec sheets and do it by the letter to be assured of good adhesion.
Old 09-19-2003, 11:15 AM
milo's Avatar
point on positive
I sometimes put a base color on a helmet,cycle gas tank or car hood and turn it over to my airbrush artist who will spend up to 6 months doing artwork and then we clearcoat. Useing PPG's DCD35 ect. Can't say I've had a failure yet. First coat of clear going on is a real mist coat.
Old 09-26-2005, 08:49 PM
paint
What base coat & clear are you using ?
Old 09-27-2005, 01:40 AM
milo's Avatar
point on positive
Yep , 2 years later... time to clear for sure
Old 09-27-2005, 04:54 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
If I go longer than the 24 hrs (DuPont says is the max)
I just lightly sand the surface and re-base a couple of coats.
Usually with graphics I clear a couple of light coats after
any base, then when it's all done I wet sand everything and
clear as normal.
Old 09-27-2005, 05:11 AM
What kind of paint are you using?
Old 09-29-2005, 10:49 AM
New Member
base clear
HOK has an intercoat clear for use in layout over base coat. I know of some other similar products in other paint lines. Some base coats you can add a hardner to to extend the open time for clearcoat. You need to check more info on the particular system you are using or find one that will be more time friendly for your layouts timewise.
There must be some custom painters on here with more experience.
overspray
Old 09-29-2005, 11:07 AM
New Member
Overspray,
Does PPG have an intercoat clear?
Bruce
Old 09-29-2005, 11:11 AM
New Member
base clear
I'm not sure. Most of my recent experience is in european systems that are in use here in the USA. PPG is hooked up with ICI Autocolor now. I guess we should check those websites for info.
overspray
Old 09-29-2005, 11:48 AM
jcclark's Avatar
The Penny Pincher
Be carefull with HOK intercoat, it worked great over the HOK base for me
but I had all kinds of problems using it over DuPont base.
It is also harder to sand than urethane, I've quit using it.
Old 09-30-2005, 07:40 AM
PAS55's Avatar
I see this post has come back ,I did the paint and took the advice and did it all in one loooong day, came out very good. I used the Nason paint.
See my album for results it was the wagon.
Garry
Old 09-30-2005, 08:13 AM
jcclark's Avatar
The Penny Pincher
Looks great.
Old 09-30-2005, 08:45 AM
New Member
b/c
I LIKE IT!!! Good job!!!
overspray
