To many factors here that we don't know to explain why you lucked out but it could have just went south as soon as you sprayed the base. What was the ISO ratio in the can of activator 30, 50, 70? makes a big difference, what base did you use? Some bases can handle as high as an 8:1 mix of activator and there are some that lean more toward the polyester side that 4oz to a mixed quart can gel or cause the base to gum up. Solids, resins and ISO solids all played a part, since you say your in Europe then most likely four years ago you used a modified acrylic type resin base with a weak activator and lucked out. Don't look a gift horse in the mouth, if what you say is true, the first bouncing stone you hit on the highway will leave a lovely chip in the paint as your paint is extremely brittle. |
Thanks for your reply Barry
The base was Dupont Centari and I'm not absolutely sure but I think the hardener's ISO ratio was 50. I don't use it anymore (PPG). No ships in the paint for now but I guess it could happen at any time... Planning a complete repaint probably next year so I don't mind, was just curious.. So luck and kind paint might be the explanation Here she is: cheers Leo Last edited by 67' bug; 06-02-2007 at 03:24 AM. |
Enamel!
That explains it. I had been stewing on how you could have cleared the base mixed like that and still get a clear to not blow up, if even possible. With the enamel, no big deal, not great but as long as you had high humidity when you painted the car, it would cure out OK. |
| Acrylic Enamel vs. Base Coat Clear Coat | 70chevy | Body - Exterior | 175 | 11-11-2009 02:07 PM |
| How to spot repair base coat? | formula_pilot | Body - Exterior | 3 | 04-15-2007 08:53 AM |
| "Basic of Basics" How do you properly apply filler? | Centerline | Body - Exterior | 2 | 02-10-2006 12:22 AM |
| What HotRodders.com looked like four years ago | TooMany2count | Hotrodders' Lounge | 2 | 04-21-2004 08:28 AM |
| 40 years ago this week | Shortstep | Hotrodders' Lounge | 11 | 11-18-2003 08:40 AM |
