base coat paint and base concentrate questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-01-2006, 09:55 PM
student blake's Avatar
official pimp
hey guys, i was just wondering even though you all will not recomend it but is there a website that sells fairly decent knock off brands of basecoat that wont break the bank? i just need black, but the cheapest i can find is r-m brand and its 120 bucks a gall.
next question is what the crap is base concentrate? sem makes it and it doesnt really say what it does? heres the link-http://www.handsontools.com/store/show_product/?product_id=18847355 any ideas?
Old 08-01-2006, 11:41 PM
Last journal entry: final pics of first engine swap
Have you seen the price of SPI black? Its $75 a gallon. Quality black too. Heres there pricing info and even some good primers and clears that might fit your budget compared to what your talking about.
http://www.southernpolyurethanes.com/Pricing%20Info.htm
Theres also Nason Fulthane and Omni that might also fit your budget. But hear that Omni might take a few more coats for coverage. I have to go more inexpensine which I don't want to do. Just trying to figure it out like you, and know it can be hard to ask about what kind of paint sometimes. hth
Just some thoughts from what I gather, I hear the Nason Fulthane being more user friendly than Omni. Great reviews on the SPI. But I think its the more expensive of the three I mentioned. I'm sure theres other good stuff out there at reasonable prices as well.
Old 08-01-2006, 11:51 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
The Sem base concentrates are mixed with an intercoat clear to make a base color of your choice..Usually about a pint of base concentrate to a gallon of intercoat..
Catalog?? Right here
Sam
Old 08-02-2006, 12:00 AM
Oops, just wanted to make an apology. Your asking about Base Coat. Not urethanes and acrylic. Just trying to learn. Shouln'dt suggest on paints yet
Old 08-02-2006, 02:01 PM
official pimp
Sam
will intercoat clear stick to primer, my shop teacher said that top coat clear wont, is it different or is he rong
Old 08-02-2006, 02:31 PM
Wiki Edits: 3
SPI top coat clear will stick to primer just fine..Ido that all the time for certain things..
But now to your question as to how to get a decent paint job at a reasonable price for materials..
Use the Black single stage over a 2K primer..You will need a gallon of primer..a quart of primer activator..a gallon of the single stage base..4 quarts of activator ...a gallon of probably 885 slow reducer as it is hot in OK this time of year..
Copies of tech sheets:
http://southernpolyurethanes.com/Tec...le%20Stage.htm
http://southernpolyurethanes.com/Tec...d%20Primer.htm
Those two items will give you a nice job for not a lot of cash and the material will work well for you..
Sam
Old 08-02-2006, 02:37 PM
official pimp
Sam
theres a problem with this though, i want a candy Orange finish with green ghost flames, i got all the candy and pearl ordered and it would be to expensive to use single-stage and go back over it with clear, so my thinking was find the cheapest way to make Candy burnt orange or what every you like to call it, (dark dark copper orange) and lay down my flames and do my ghost flames, and then clear the whole think what would be the most cost efficient way to achieve this look?
Old 08-02-2006, 07:48 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
Your doing a kandy job and you want a cheap base to put it on?
BTW, What products are you using for the kandy & pearl work?
You won't find a cheaper base than SPI for the money and the quality is compairable with any TOP line paint.
Old 08-02-2006, 08:57 PM
Wiki Edits: 3
Arrrgh..I thought you wanted a black car when done..the candy is a whole nother deal
Use this in black for your base..
http://southernpolyurethanes.com/Tec...y%20Primer.htm
Use this to blend your base color:
http://southernpolyurethanes.com/Tec...er%20clear.htm
It is absolutely imparative to do a layout..that is a test panel when painting candies as they are not all alike..Might take several coats to get the color to suit..
Once the candy is down then shoot a coat of intercoat..tape off for your flames and shoot them..
Once that is done follow up with 2-3 coats of Universal Clear..
http://southernpolyurethanes.com/Tec...ne%20Clear.htm
Candies are never cheap as it requires quite a bit of paint to do..
What I have outlined is how I would go about it but then there are others who have their own ideas of how to do a candie job..
Sam
Old 08-02-2006, 09:49 PM
official pimp
thanks sam, this is exactly the help i needed
btw, how many coats of the candy do you think it would take?
Old 08-02-2006, 09:58 PM
Intercoat clear will stick to primer and your shop teacher is wrong, topcoat clear will stick to primer the same as singlestage urethane sticks to primer as long as the primer is sanded/scuffed properly. But to do a candy you'll need to apply a base color, silvers and golds are the most common but any color can be used solid or metalic to achieve the effect you're after. You're taking on quite a challenge doing a candy if you're new to this kind of work.
Old 08-02-2006, 10:02 PM
official pimp
dont take me rong, im going to practice with it to get it right, im only 17and have been doin paint for only a couple of years, but i want to learn and do as much as possible, i just got accepted into uti, huston, for the auto body program and i am lookin forward to it, all i am really interested in is custom paint
Old 08-02-2006, 10:25 PM
Blake, I wish you luck on the career and with your interest I'm sure you'll do good. The amount of candy needed is going to be determined by how dark you want the color to be and how concentrated the candy is. Based on the jobs I've done it always took at least 4 coats and some took up to 8 coats. When you shoot your testpanel you'll find out how many coats are needed and can order up more paint if needed. The weaker the dye concentration the easier it will be for you to get an even application with no light or dark spots. Plan on walking the full length of the car when applying the candy so there's no light or dark spots from starting and stopping, don't forget to shoot the rockers-my first candy looked really good untill you looked at the bottom of the rocker panels. Bob
Old 08-02-2006, 10:33 PM
official pimp
thanks for the help guys, im sure with the advise you all have given me i will do fine
Couple of base coat/clear coat questions bigbrowndog Body - Exterior 17 11-05-2010 08:37 AM
"Basic of Basics" How do you properly apply filler? Centerline Body - Exterior 2 02-10-2006 12:22 AM
About to spray base coat, newbie question... flipp121 Body - Exterior 20 10-16-2005 08:52 PM
Couple more paint questions firechicken383 Body - Exterior 12 09-28-2005 07:22 AM
Couple of paint questions firechicken383 Body - Exterior 5 09-22-2005 09:18 PM
