Base Coat Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2005, 07:21 PM
Base Coat Question
I'm doing an engine compartment BC/CC. I have about 3 coats of base down and have sleight ,or a little more than sleight, orange peel. Will the clear hide this? It doesnt have to be perfectly smooth and deep since I'm trying to do an original type resto but I dont want it to be any worse or have the clear make th orange peel stick out like a sore thumb.
PPG DBC and 2021 clear. I think my problem was air cranked up too high, I had it set at about 55 psi and gun says 43 but the pattern looked a lot better with more air when I did a test panel. doing clear in the morning. Thanks
Bert
Old 07-11-2005, 07:28 PM
it's hard to say without seeing it , but the clear should bury some of it . after the clear dries , you can just knock it down to get your desired orange peel , then buff to get your shine.
Old 07-11-2005, 07:52 PM
here's a few pics. first one is the worst of it, the rest looks like second pic
Old 07-11-2005, 08:02 PM
it'll be fine , clear it.
Old 07-11-2005, 08:08 PM
well guess I can only get one photo up but this is the worst of it and the rest looks pretty good
Old 07-11-2005, 08:27 PM
mrcleanr6's Avatar
it looks fine, clear it!!!
Old 07-11-2005, 09:21 PM
thanks. Going to clear in the morning wile its still cool. Paint went on this afternoon and the car was pretty warm.
Old 07-12-2005, 05:41 AM
If you were after perfection the paint would need to be sanded smooth and another coat of base applied, but since this is a restoration it should be fine with a little texture in it. Looks like a Mustang? Bob
Old 07-12-2005, 08:03 AM
thanks Bob , it's a 69 Dodge Superbee
pinstriping base coat / clear coat apehanger mike Body - Exterior 1 01-30-2005 12:28 PM
Clear Coat Question mkleisch Body - Exterior 21 08-11-2004 01:06 AM
Hotrodders Guidelines -- READ ME Jon Hotrodders' Lounge 0 06-14-2003 05:08 PM
Knowledge base question about Isky cam? slider in wa Engine 6 03-06-2003 06:53 AM
