Base coat wait - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-17-2012, 11:32 AM
Base coat wait
I just sprayed my truck with Nason base coat. Nason says wait at least 30 minutes before you clear coat. I have SPI universal clear they say in their catalog to wait until the next day. It has been about an hour now and I want to spray now. Has anyone sprayed SPI clear without waiting until the next day? What would be the minumun wait time? Thanks Ron Hope some one answers quick it is getting hot in the shop today and I can't wait to see that SPI clear done by this amature. I called SPI and got a recording.
Old 03-17-2012, 12:36 PM
swvalcon's Avatar
Last journal entry: rust on lt body shell
Any time after about a hour you should be fine I've went anywhere from 45 mins to 2 days . Your shop and air temp is the big thing If your 65-70 anything over a hour will work. Dont rush your clear coats I give it ahour or so between coats.
Old 03-17-2012, 01:43 PM
I went back and read the PSI booklet, and it said for a shop job, not a show car, you can spray again after 3 min. up to 20 min. It had been about 12 min. so I started spraying and it came out great for a beginner. And the book said all I needed was 2 wet coats I'm glad because I only had a tea cup left over. I only had 3 runs, an easy fix, I hope. I will get some pictures on here after I finish the bed and bolt it on. Thanks Guys.
Old 03-17-2012, 03:13 PM
swvalcon's Avatar
You never want to go with the lowest time on anyones sheet. That's if every thing is perfect and We all know how often that happens. Glad it worked out for you. Give it a little more time next time. This is one case where more is better.
spot repair of metallic black base coat clear coat on bumper bar pinkotoo Body - Exterior 0 02-25-2012 04:35 PM
Question about touching up Base Coat/Clear Coat TR4AGuy Body - Exterior 0 10-08-2011 02:57 PM
Base coat/clear coat urethane over acrylic enamel mervhudson Body - Exterior 5 04-23-2011 10:56 AM
base coat paint and base concentrate questions student blake Body - Exterior 13 08-02-2006 10:33 PM
laquer primer/ppg base coat/clear coat? dave mc Body - Exterior 5 10-11-2005 04:59 AM
