base over clear - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2007, 05:38 PM
base over clear
Gents,help please. Recently painted my car. 1st time,not bad,but I'm considering a do over.Seeing as the body work is already done can I rough up the clear and spray base directly over it without using a primer coat.
Old 06-13-2007, 05:47 PM
Yes, but not too rough, 400-600 paper wet will do.
Bogie
Old 06-13-2007, 08:21 PM
302 Z28's Avatar
Perfectly acceptable, but do not use a too agressive sand paper. One very important tip I can give you is this. After you sand the clear set the car in the sun for an entire day before you re-coat. This allows any trapped solvents in the clear to gass off. Skipping this step runs the risk of solvent pop.
Vince
Old 06-13-2007, 08:23 PM
Last journal entry: Latest picture
Or worse!! wrinkling the clear. If the clear is not fully cured you can use a non-penetrating basemaker, or a very fast drying one. I use Dupont 7155 on repaints, and don't lay it on too thick. Dan
Old 06-14-2007, 11:25 PM
Countilaw's Avatar
Cox Custom Cars
You can also use Scotchbrite pads to scuff up the paint. I have a DA with scotchbrite on it for just this purpose. After Scuffing, let sit in the sun for the afternoon.
Next day, wash the car with Dawn and water, blow dry, and wipe with car with rubbing alcohol and soft cotton cloth. This will remove any oily hand and or finger prints. Tack and shoot.
Mix Clear with Final Base coat prior to clear x711 Body - Exterior 10 04-08-2006 08:55 AM
Wetsanding Clear and Metal Flake on Edge Phillip27 Body - Exterior 11 01-20-2006 03:52 PM
Dupont Clear over metallic base dave220 Body - Exterior 5 04-01-2005 09:16 PM
Which type, base coat clear coat or.. Rubberman2003 Body - Exterior 20 12-19-2003 02:09 AM
