Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Base Timing - Advance timing
Old 05-10-2004, 11:17 AM
chevelle67 chevelle67 is offline
All right another question for you guys, since you did very well on the last one. I got a 327 SBC and I have the base timing set for
4 degrees. My question is 2 part what should the advanced timing be? Can I run the engine without vacuum advance? I was told that I should be around 34 advance without the vacuum advance and install the vacuum and if it goes up to 45-50 degrees don't run it. What do you guys think
