Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Base Timing - Advance timing
Old 05-11-2004, 08:45 AM
Frisco's Avatar
Frisco Frisco is offline
Glad To Be Here
Originally posted by chevelle67
I guess that info would help a little. The engine is 10:1 compression the cam is a 230 duration with a 480 lift and it is running on pump gas 92 octane
A good starting point would be 10-12 degrees initial and 34-36 Total mechanical (initial plus mechanical) all in around 2500-3000 RPM. Set this with the vacuum advance disconnected and plugged. Re-connect the vacuum advance after you have set the timing.
Don't worry about what the timing shows with the vacuum advance hooked back up as it will not function at WOT. You may wish to limit how much advance the vacuum pot gives you by using an adjustable one. Try it first to see.
If you get pinging when in high gear going up a slight hill at a moderate speed; back off the timing 2 degrees and re-test until no pinging occurs.
As to running the engine without the vacuum advance; Yes you can but for street application I would not. The vacuum advance is designed to improve the overall driveability and gas mileage. For a race only application it is not neccesary because you would be at WOT and there is '0' vacuum at that time and therefore the vacuum advance will not function.
